NI 9228 No channels
Hello everyone,
new LabView user here, so please bear with me.
I am using a cRIO 9066 on which I have several modules, including an NI 9228 Analog Input Module.
I can see every channels of every modules, but none of the Analog Inputs from the NI 9228.
Am I missing something? Driver? Faulty unit? MAX configuration?
As you can see on the screenshot, I have a drop down list on every module except on the NI 9228:
I am using LabView 2017 SP1 on a Windows 7 PC.
Thank you for your help.
(2,446 Views)
I beleive it is because you are trying to use it in Scan mode. Add a FPGA target in the cRIO and then add the 9228 module in FPGA, you will see the channel list. You can alse see the example in the example finder.
CLD Using LabVIEW since 2013
(2,422 Views)
