NI-9266 Analog Output Module
Hello, I was inquiring about a problem that occurred to me when I was trying to operate the NI-9266 Analog Output Module, When I gave it power [24V DC] and it was connected to a NI-9147 chassis it gave out this warning [65543] and the card did not output any current.
I also tried it on a different chassis [NI-9149] in a completely different setup with supply voltage [9V and then 12V] and it still gave me the same warning, attached is a picture of the warning from LabVIEW.
The code is just a while loop with a 50ms wait and an analog A0 shared variable that has a controller wired to it.
Message 1 of 1
(619 Views)
