NI 9476 open/close channels
Hello all,
I am very new to controlling Compact Rio's
I want to make a small program which simply opens and closes channels in the NI 9476 (if this is even possible).
However, I have no clue how to send a open/close command to this device.
The device is configured in MAX, and the channels are named.
I've read the Operation Manual, but couldn't find much usefull information for my problem
Does anyone have a small example or code for this problem ?
Thanks!
(3,650 Views)
Dear WickedWalker,
thank you so much for your post on our webforum. What configuration are you using (which chassis and which controller?); do you want to use the module through the FPGA (using the Labview FPGA module) or only with the scan engine (only using Labview RT).
Martijn S
NI Netherlands
(3,555 Views)
