NI-9505 DC bus voltage measuring
I would like to use NI-9505 H-bridge module in a drive identification system
where I have to measure the DC bus voltage as well.
Is NI-9505 capable of this?
Thanks.
Pros
(3,762 Views)
Accepted by topic author K_LAMAR
Hi Pros,
NI 9505 module is DC Servo Drive module. However, it doesn't provide general (voltage) analog inputs, as you would need.
However, I believe that you have chosen modular platform like cRIO, which means you can add another functionality by adding one more module to it. Check C-Series Voltage Acquisition products for choosing the best suitable device for you.
You can use NI 9215 to measure voltage, for example in addition to NI 9505 module.
Stefo
(3,735 Views)
Thanks.
I thought so. I just wanted to avoid cross-wiring between modules.
P.
(3,726 Views)
