NI 9625
Does NI 9265 (analog output current module) compatible with cDAQ.
Or it is only compatible with cRIO.
Thanks.
WAQAR
(5,694 Views)
You can use the NI 9265 with cDAQ, as you can check at the following link:
https://www.ni.com/en/support/documentation/supplemental/08/c-series-module-and-compactdaq-compactri...
(5,677 Views)
