NI 9704 9505 (How to Disable Error checking)
How to disable NI 9505 Error Checking. The target position is too large and bigger than 32767. Consequently, the motor is disabled and never run. Thank
(3,780 Views)
Hi zjc1,
Can you give me a little bit more information on what Error Checking you are talking about.
thanks
Flash
(3,768 Views)
Hi Flash,
I refer to Position Eorror checking. For example. the current position of motor is 0; and the target position is 32769. When I set the target position to 32769, the real-time FPGA demo labview code will never run. The labview will say that there is a position error. Do you known wheather can I disable the possition error checking. Thus, I can set the target position to desired position. Thanks
Zjc1
(3,734 Views)
Hi zjc1,
I am not sure which example you are referring to. Please let me know and I will be able to help you a bit more.
Flash
(3,725 Views)
