NI 9870 module
Hi
When i open the Distributed System Managerand and i Eexpand my CompactRIO system in the left-hand column
i dont see my I/O module (NI 9870) listed below my CompactRIO system.
Can you tell me why?
regards
Message 1 of 32
(7,003 Views)
moonm,
This is expected behavior and likely happens for the same reason as this.
Message 2 of 32
(6,996 Views)
Hi Wayne.C
In the MAX , underneath my cRIO softwares i see "NI serial RT 3.6.0" .
is it other softwares to install for NI 9870 ?
regards
Message 3 of 32
(6,980 Views)
That will depend on whether you are running the 9870 in FPGA or scan mode.  What version of LV are you running?
Message 4 of 32
(6,978 Views)
I want to use the NI 9870 with LV FPGA..
i have LV 2010
and this is my MAX:
Message 5 of 32
(6,976 Views)
Since you are going to run in FPGA mode, you won't need to add the scan support for the 9870.  Looks like you have everything that you need loaded on the RT target.
Message 6 of 32
(6,974 Views)
Thx
Can you give some link to help me how to use NI 9870 with LV FPGA
I want to send command to my periphiral then read what i recieve
Message 7 of 32
(6,972 Views)
There is a very good example that ships with LV.  Just do a search on 9870 in the examples.
Message 8 of 32
(6,955 Views)
Hi Wayne.C
I have already moved the exemple to my project CompactRIO, but when i want to run a VI for example the " 900x 9870 DMA Config (Sub).vi "
I find these errors
Can u explain why these errors and how correct them
Message 9 of 32
(6,927 Views)
moonm,
Can you post an image (.png) of your Project Explorer window so I can see how you have your project set up?
Message 10 of 32
(6,925 Views)
