NI-RIO, Error -63040 (kRIOStatusRPCConnectionError):
I'm trying to setup a Compact Rio 9014 with labview 8.5. In the project manager, I can detect and setup the system with all the modules, however the folders are grayed out. When I drag a module into a vi a new vi crated under the rio in the project maanger, the input says it cannot access the compact rio system. I started up MAX and I can see the rio, do software updates but I get an error message stating ni rio - error.
A connection could not be established to the specified remote device. Ensure that the device is on and accessible over the network, that NI-RIO software is installed, and that the RIO server is running and properly configured.
For NI-RIO 2.3 and forward, refer to Software>>NI-RIO>>NI-RIO Settings under the system in MAX.
Prior to NI-RIO 2.3, refer to Software>>NI-VISA>>VISA Options under the system in MAX.
And in this view, you can see that the modules and their channels are grey( they should be yellow folders)
(5,191 Views)
Half way there, I hooked up the cRIO to another computer and reinstalled the software to the unit with a minimal instal. I connects and configures fine in MAX back on my desktop but i still get grey folders and am unable to read any data. is there a step I am missing?
(5,190 Views)
Nevermind, got my eureka moment. I am used to using fieldpoint realtime, had no idea how the fpga came into play. i tried searching ni and google but nothing other then playing around the project manager , did i figure how to configure a fpga vi for each module.
(5,187 Views)
I'm glad to hear you got things working.
For reference, we also have a great KnowledgeBase article that talks about this error message.
Eric V
Certified LabVIEW Associate Developer
"I'm a Ramblin' Wreck from Georgia Tech and a helluva (NI Applications) Engineer!"
(5,176 Views)
