NI USB FPGA 7845R: Windows-only Support vs. Real-Time Requirements – Need Solution
Hi NI Community,
I’m reaching out because I need to achieve real-time control using the NI USB FPGA 7845R, and I’m running into some challenges that I hope someone can help me resolve.
The Issue:
  • The NI USB FPGA 7845R is supported only on Windows.
  • My application demands precise, deterministic timing—true real-time control.
  • The current setup uses a labview host VI that communicates with the FPGA via DMA FIFOs, but this host VI runs on Windows.
  • Our high-level controller runs on real-time Ubuntu and communicates with the host VI via UDP.
  • The bottleneck is the host VI, which, running on Windows, cannot guarantee the required real-time performance.
What I’ve Found So Far:
  • The device’s driver and software stack are strictly Windows-based.
  • Windows cannot provide the determinism needed for our control application due to these delays.
What I’m Looking For:
  • Is there any workaround or method to run the host VI on a real-time operating system, or otherwise mitigate these delays?
  • Has anyone successfully achieved deterministic timing with a similar setup, or are there alternative solutions you’d recommend?
I appreciate any insights or suggestions you might have. Thanks in advance for your help!
(1,001 Views)
The LabVIEW FPGA module requires windows to program the fabric and all real-time control should probably happen inside the FPGA. I don't think UDP communication is suitable for "real-time control". (Sorry, I am not familiar with this device)
I have the feeling that the realtime forum would be more suitable for this discussion. Let me know if I should move this thread.
(987 Views)
Thank you for your response. Yes, please move this thread to the real-time forum.
(981 Views)
Unfortunately no. That's the limitation of a USB-based R Series device. If you need the RT determinism, you should get a PCI(e) or PXI(e) based module instead.
Other possible workarounds:
https://tmesystems.net/
(925 Views)
Thanks for the suggestions.
I’m curious if it’s possible to mitigate the Windows-induced delays using a real-time extension like IntervalZero RTX64. From what I understand, RTX64 can provide a deterministic, real-time layer on top of Windows. Has anyone had any experience running labview using RTX64 (or similar solutions)?
(907 Views)
