NI-XNET Bus Monitor
Goodmorning I am using NI-XNET Bus Monitor from Veristand and I want to read CAN message, from PXIe-8510. If I display the message without Assign Database Alias (Screen1), then I have the column Frame Name (Screen2), but I can't see nothing: the name of the message is not appearing. If I Assign Database Alias, then I don't have the column Frame Name (screen3). How can I see the Frame Name, when I set a database alias? Or there is another method to decode the message? Thank you
Message 1 of 1
(1,138 Views)
