NI cRIO 9030_An Input Parameter is Invalid When I Launch my RT Application
Hello, i work with an cRIO 9030, LbV Version 2020 and programmed a real time application. I can run my software with my Notebook and a direct connection without any errors.
But after i have build the RT_Application and start it after a reboot on rio, i get exactly this information:
"An Input Parameter is Invalid When I Launch my RT Application".
I also found an information about this error here:
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z000000kGBgSAM&l=de-AT
but i don't understand, which file path exactly is meant?
my builds are in the following order: C:\Users\iftadmin\Desktop\Stefan\builds\TB  at my windows development system and if i deploy the file, i can found it at my linux system in "file system" -> /c/ni-rt/startup
there are two files called: startup.aliases and startup.rtexe
which "path" is meant? - i can't understand this information.
i would be very greatful, if anybody can help me with this problem?
With best regards
Stefan
(1,422 Views)
Does anybody have some ideas? how i can safe that problem?
with best regards
Stefan
(1,243 Views)
