NI crio 9014 error: Error -63196 (kRIOStatusInvalidAttribute): An invalid attribute has been specified.
I am using NI MAX to communicate my cRIO 9014, and it can be recognized.
But when I click the item in Devices and Interfaces, it shows an error:
My question is how to solve this error, so that I can list the modules installed in the cRIO 9014.
(2,738 Views)
I am no help here. I am having the identical error. Looking forward to any suggestions. I am working with a cRIO-9022 controller. I am only powering it with a 24V power supply rather than the recommended full 36V. Could that be an issue?
(2,647 Views)
Did you find any solution for your error? I am experiencing the same problem.
(2,483 Views)
Hi, which version of LV+drivers are you using?
(2,421 Views)
