NI9237 Fehler Msg
While compiling the example lvproj for NI9237,i got this error msg.
Pls help to fix this,i can switch the deice to full bridge only here.
(3,543 Views)
could you please post your project, so that we can try the compile ourselfs?
Christoph
Staff Applications Engineer
Certified LabVIEW Developer (CLD), Certified LabVIEW Embedded Systems Developer (CLED)
Don't forget Kudos for Good Answers, and Mark a solution if your problem is solved
(3,513 Views)
It is not my code,it from the examples.
(3,487 Views)
