NI9775 compatibility ?
Hi, I recently found the NI9775 module in the list of cRIO modules (https://www.ni.com/en-us/shop/model/ni-9775.html). Weird, it is not listed in other places like the CompactRIO guest page (http://sine.ni.com/np/app/main/p/ap/global/lang/fr/pg/1/sn/n25:device,n24:cRIO/) or the C Series module compatibility chart. From the détailed description and manuels, I suppose the module is only compatible with cRIO; however, as I still have a slight doubt, I was wandering if somebody already used this module and if it is compatible with the cDAQ platform.
(2,998 Views)
DAQ compatibility should be released with the next DAQmx driver. Currently, NI 9775 is only compatible with cRIO ( driver CompactRIO Device Drivers 2016 + CompactRIO Module Support 16.1)
https://www.ni.com/en/support/documentation/compatibility/09/software-support-for-compactrio--compac...
(2,979 Views)
