Need 8.2.1 versions of TAE and TPD
I am looking for an 8.2.1 version of the TAE and TPD components for cRIO.
I tried to upgrade to 8.5 but my RT/FPGA application will not run in 8.5 yet.  This was confirmed by technical support.
(3,823 Views)
Hi TLE
Are you planning on using these components with Windows XP or with the NI Touch Panel Computers?  The reason I am asking you this is because the TPD won't work with version 8.2.1.  The TPD uses some of the new property nodes in LabVIEW Touch Panel Module version 8.5.  If you are using or planning on using it on LabVIEW for Windows XP (on a host PC) then there is no problem, both components will work fine.
Could you give me your contact information so that I can e-mail you or call you directly? I can give you the 8.2.1 versions but again, it all depends on the OS target.
If you don't want to post your e-mail or phone number, just post your Service Request number and I'll get your information from there.
Thank you,
Ricardo Santa Olalla
Systems Engineer
(3,726 Views)
My most recent service request number is 7176891.
I am using LabVIEW 8.2.1 deployed to a cRIO-9014 and a TCP 2012.
(3,724 Views)
