Network Shared Variable Stuck True
I have a boolean NSV on a cRIO that now seems to be stuck in a True state.  All Vi's on the cRIO are stopped, LV is closed on my development system and yet in the DSM I can try to set the variable to False and it will pop back to True.  I do not (should not) have any bindings to this variable.  It would be nice to be able to get a complete view of the internal state of a NSV engine to see if there is some weird cross linking or stray deployed variables.  Has anyone seen a probem like this?  BTW, I am running under LV 9.0f2
(3,389 Views)
Accepted by topic author viScience
Ok - Problem Solved, (should of had my coffee before posting).  Just forgot about a remote HMI that was running and was causing the mysterious behavior.
(3,388 Views)
Glad you found the solution, but that would be a good idea to post in the idea market.
Something like, "Ability to view all remote connections to a PSP host"
Kurt
(3,362 Views)
