Network Variable Engine on QNX Neutrino
Exists something like NVE for QNX Neutrino? Or is it necessary to do all the communication
"manually" via TCP/IP?
Regards
Nicolas
(5,182 Views)
I haven't any information about network communication unfortunately...
Pelle S
Account Manager
National Instruments Sweden
(5,166 Views)
Hi
Thanks for the info. I solved the problem by simple tcp/ip connectinon. So far it works quite well.
But I have another question:
is it possible to pass data between two while loops on qnx? The global and local variables do not work
(random data). Is there any other way?
souske
(5,100 Views)
I guess you could use functional global variables, i.e. a subvi with a uninitalized shift register.
Hope it helps.
Pelle S
Account Manager
(5,098 Views)
Thx for the answer. I used queues . They work pretty well too.
souske
Message Edited by souske on 02-12-2008 11:05 AM
(5,097 Views)
Do you know if the Timed Loop actually works on QNX? For example hiher and lower priorites if I use 2 loops?
(5,092 Views)
Timed loops should work on QNX. However, the clock will probably only be in the order of ms.
Pelle S
Account Manager
(5,042 Views)
