Network communication problem.
Greetings,
I am using LabVIEW RT 8.5 with a cRIO 9012 controller and TP Module 8.5 with a TP-2012 to communicate with the controller via shared variables over wireless LAN.   Everything was working fine then all of a sudden the system stopped responding.   I can download applications to both devices, access ftp on both devices, surf the web on the TP-2012, but my application will not run.  If I run the application from the desktop computer it appears to be in run mode but nothing is happening, if I probe wires it shows no activity, there's no activity on the front panel, as if no communication is going on between the PC and the controller but I can run the Real-time system manager and it will show cpu activity.   I don't get it, if it were a network problem I wouldn't be able to do anything with the devices over the network, at least thats what I thought.   Could anyone shed some light on what is going on here please?
(4,414 Views)
I think I figured out what I did...   I am using the a 9205 input module, I remember changing a couple of the inputs from NRSE to DIFF without recompiling the fpga code.  It is now compiling, I will report back with the results.
(4,409 Views)
Bad programming on my behalf.   Forgot to wire the error status to the conditional terminal of one of my loops so every loop stopped except that one.
(4,407 Views)
Thanks for posting about the resolution,
Alejandro
(4,334 Views)
