Network settings tab is blank
Here is a fig of how it looks when connected to port 1 and 2 respectively. I also see that the DNS name did not say .local in my first screenshot from last week.
Message 21 of 24
(3,757 Views)
Accepted by topic author glorias
Hi glorias,
if you reboot your cRIo-9068 to a safe mode, are you able to see something on the network tab. So check the Force Safe mode selection in the System Settings. And then reboot the 9068.
Br, Jorghos
Message 22 of 24
(3,722 Views)
Hi Jorghos!
Sorry for late response, but this actually worked, thank you very much! I also changed some things before that, allowing java scripts, active X etc. But this was the final thing that made it work and now I do not dare to change anything else back to start with.
Thank you for all the help from everyone!
Message 23 of 24
(3,683 Views)
Hi glorias,
great that it helped. I don't know what setting caused this but usually the safe mode can help on getting the system back to a normal state.
Br,
Jorghos
Message 24 of 24
(3,668 Views)
