Not able to configure cRIO-9036 to DHCP only mode programmatically
I have cRIO 9036, I am trying to set it to "DHCP only" mode
 From NI MAX
  1. I am able to configure Ethernet Adapter eth0 to "DHCP only" from MAX.
  2. Save
  3. Restart
  4. NI Max cannot find the cRIo until cRIO obtains IP address from a DHCP server. - This is fine
Now Programmatically (attached Code)
using nisysconfig.lvlib and property node, when trying to set the cRIO in "DHCP only" mode.
I get error -2147024809.
LabVIEW: (Hex 0x80070057) One or more arguments are invalid.
NI System Configuration: Invalid parameter.
If it can be done from NI MAX, then it should be possible programmatically. What am I missing? Please find the attached code.
Please help.
Narmada
Message 1 of 1
(1,998 Views)
