Not enough memory on CRIO to upload libraries
I use CRIO 9012 with 64 Mb RAM memory, but this memory is not enough for my application code. Is there any possibility to place all or some of the libraries which i use in the code on the hard disk, instead of the RAM memory?
(3,511 Views)
You can always FTP your library to the ni-rt/ or the ni-rt/system/ file directory. You need to ftp these because Labview does not support autoloading to a VxWorks target. You should also keep in mind that when you call the library, whatever you call will obviously be open in RAM. Here is some basic information to answer any of the other questions you may have on this topic. Also if you are interested in upgrading, the 9014 has twice as much DRAM at 128 MB. Also the 9075 (which costs less than the 9012) has twice as much DRAM as well, unfortunately for this product it won't ship until earliest June 2011. There are other things that you would need for the 9075 which may hinder that decision, (for example the need for a usb port), however, I wanted to provide it as a possible option.
RIO Embedded Hardware PSE
CompactRIO Developers Guide
(3,510 Views)
