Not supported ethernet card for RT
I am in the process of setting up PC as my real time target. When I try to install the LabVIEW RT, I encountered not supported ethernet card.
My card is "Integrated Intel® 82567LM Ethernet LAN 10/100/1000" and the recommended one is "Intel® 82567 "0x10BE" and "0x10F5"". Are they are different thing? Is there a way to make this work without changing the hardware? Thanks.
(3,546 Views)
simply_ynan
That chipset is not officially supported but it may work you can try using the Real-Time PC checker: http://digital.ni.com/public.nsf/allkb/9209361E17708D548625744A007FF353?OpenDocument 🙂
And here is some other links that may help:
http://zone.ni.com/devzone/cda/tut/p/id/2733
http://zone.ni.com/devzone/cda/tut/p/id/8239?OpenDocument
I hope this helps 🙂
Sam S
(3,538 Views)
