Open FPGA vi gives xnode error (Lv 8.6) (not executable)
Hi
I wrote my error description also here: http://forums.ni.com/ni/board/message?board.id=280&message.id=5055&jump=true#M5055
When using "execute vi on development computer" I get a broken error pointing me to the "open FPGA vi function", with the problem
being "an xnode is not executable". I havent found anywhere this problem being discussed, I tried deinstalling FPGA and Rio soft,
and resinstalling, but to no help. Any ideas are welcome.
Staffan
(4,197 Views)
Accepted by topic author Segeltamp
Hi
JMota wrote :
"Here is one thing to try. I think configuring your FPGA Target to run on the Development Computer (with Simulated I/O) will not work if you try to run your Host VI on RT. Try dragging the VI to My Computer and run it from there. Altenatively,  you can reconfigure your FPGA Target to not run on the Development Computer (what used to be called emulation).
Hope that explains why the VI was broken."
And it solved the problem - running fine now - so this question is solved.
Staffan
(4,175 Views)
