PCI 7041 6040E
I am try to control two dc motors by taking their various encoder inputs and sending out pwm signals to control the motor. Can someone please tell me how to send pwm signals to my motors. I am using a PCI 7041 6040E real time DAQ boards.Thanks
(3,302 Views)
Emeka,
Can you please post this question on the the Motion Control and Motion Drives group? You can find their link here
LA
(3,290 Views)
Emeka...I don't think you need to post this to the Motion Control Group...it is a LV/DAQ issue. The problem is probably going to be the number of counters available to you. Normally when you read an encoder input you need to have at least 1 counter per encoder. Then you can use event counting to determine the position of your encoder. Then you need to use a counter for each PWM output that you need. The 7041 only has 2 counters which means you could only do 1 input and 1 output at a time. You can do PWM using Analog Output channels, but that takes a little more processing (and is trickier) and you wouldn't be able to run as fast. If you went with this scenario you could use the 2 counters for 2 input encoders and 2 AO channels for the signals to your motor. There are some examples in DAQmx which show how to do this (the PWM). See the DAQmx>>Control section in the example finder.
StuartG
(3,284 Views)
