PCI 7833R replacement
I want to replace my PCI 7833R FPGA card with a newer and better FPGA and with PCIe bus if possible.  I want to make as little change to the LabVIEW code as possible, but I notice the potential changes that I have to make so far.  Are there ways to get around them?  Are there more changes that I should anticipate?
1. device change.  I assume I can change that pretty easily in the project explorer.  Any pitfall?
2. The PCI 7833R uses integer to represent floating point for its analog I/O.  Other new devices use fixed point or floating point directly, which mean I have to make a lot of code change.  Can I make the new device to uses integer for analog values?
Kudos and Accepted as Solution are welcome!
(6,647 Views)
Accepted by topic author jyang72211
jyang,
Our cRIO and sbRIO products use the fixed-point data type for analog input, however all R-Series PCI & PCIe devices still use raw integer data to represent analog input.
Your code changes should be very minimal if any. You'll have to add a new target to your project and add FPGA I/O, but if you give the channels the same aliases as they had on your previous target you'll just have to drop the FPGA VI & other project items (memory, FIFO, etc) under the new FPGA target and all should be well.
Remember that you can try this and compile for a different FPGA target before you even purchase the hardware. Since you can get your resource utilization and timing reports, this might be helpful in deciding which R-Series board you'd like to go with. Take a look at the KnowledgeBase titled "How Many Slices Does My FPGA Chip Have", this will give you a rough estimate of how much larger the other FPGAs are, but it doesn't include specialty resources like DSPs, BRAM, etc.
Hope this helps!
Nick C | Software Project Manager - LabVIEW Real-Time | National Instruments
(6,634 Views)
Are you using the 7833R with Labview 8.5.1 or older?  The PCIe board is not supported until Labview 8.6.  There is a chart some where showing minimum software versions but I cant seem to find the link.
(6,630 Views)
Using 2011
(6,620 Views)
