PCI NI4351 Drivers Windows 2K problems
I have installed the PCI4351 Labview drivers/icons for Labview 6.02 and mass recompiled the program files/national instruments/Labview 6/instr.lib folder which contains all the LV6 drivers. After doing this, I notice, under Win2k that many of these vi's call other lower level vi's that are not executable but if you keep clicking the broken arrows, you eventually come to a vi that has no errors.
So how to fix this???
BTW, these same files seem to work fine under Windows 98.
Thanx, Mike S.
(3,233 Views)
Not too sure why this is the case but I have seen similar activity on machines that are running an NT based OS and the operator is not an Administrator. Be sure that you are an Administrator and reinstall the VI's.
(3,233 Views)
