PID control with crio 9076
I am using crio 9076 to control a system. I want to implement PID control to the system.Input is from RS232 serial port.
Please help me with how to use crio and PID advanced block.
(3,622 Views)
hi nehap,
did you have a look in the example finder? there are several PID examples.
and if you are new to crio, you should have a look at http://www.ni.com/pdf/products/us/fullcriodevguide.pdf
and work through the online training (Real-Time 1 and 2) (requires you to have SSP which you have if you bought labview/crio/rt) http://sine.ni.com/myni/self-paced-training/app/main.xhtml
regards
If Tetris has taught me anything, it's errors pile up and accomplishments disappear.
(3,606 Views)
hii,
Thanks for replying.
I have gone through the examples and the tutorial. I am from mechanical background and first time user of these electrical components, so was finding it tough to use.
Almost all the examples given are in FPGA mode, whereas i have to use the cRIO in scan mode. Please help.
Also, I have to connect the cRIO to stepper drive(which will be actuator)
(3,589 Views)
there are several examples for plain labview,
there are also examples for *RIO which use FPGA, but just ignore those
edit:
i used the simple PID.vi, put it in a loop, thats (almost) it
(3,585 Views)
