PXI-7833R ADC values?
I need to determine what the binary values will be when a anolog channel on this cards reads a certain voltage.  Since it will be represented in 16-bits, what will, say for example, the 16-bit value be when you measure 0Volts?  5 Volts? 10 Volts? -10Volts?
Thanks!
(3,114 Views)
If I understand your question correctly, I believe you can use the conversion method set forth in this KB.  You'll just have to rearrange things a little bit and use the range of -10 to 10V for the 7833R.
If you need more information or clarification, please post back.
Lorielle P.
(3,101 Views)
