PXIe-7857R Raw data to voltage conversion on AI port
My 7857R is configured to report AI values as Raw data.
Using the property node of the AI channel I retrieve LSB Weight and Offset.
How do I calculate the voltage using Raw data, LSB weight (U32), and Offset (I32)?
(2,622 Views)
Hi Nagaraj_Anan,
Take a look the links below
http://digital.ni.com/public.nsf/allkb/BBBD1A290BDDBF50862575AE0006124C
http://zone.ni.com/reference/en-XX/help/370984T-01/criodevicehelp/9263_converting_and_calibrating/
I am bit confused though, why are you getting raw data when you could get an engineering unit. Check this link for more information:
http://digital.ni.com/public.nsf/allkb/DD1183C27C112210862575FD006F47E0
(2,570 Views)
