PXIe 8840 running LVRT communication with Windows PC.
What is the easiest and fastest way to communicate 80 Hz data (about 80 bytes) from a Windows 7 computer to the embedded controller.
(2,333 Views)
The data is lossy or lossless?
Data Communication Methods in LabVIEW
If lossy, you should use "Variable Interfaces" method. I think "Shared Variable" is the easiest.
If lossless, you should use "Buffer Interfaces" method. I think "STM" and "Network Stream" is good.
Certified LabVIEW Developer
GCentral
(2,316 Views)
