Phase Difference Measurement by means of Digital Sampling
At 100 kHz one cycle takes 10 microseconds.  Divide that by 360*1000 to get millidegree resolution = 27.8 picoseconds.  This requires a 36 GHz clock.
Lynn
Message 11 of 14
(1,944 Views)
I'm curious. Why do you need to do this?
We are an accredited standards laboratory and our main calibration source for phase difference is a 5500-2. And it is not cheap.
If you are trying to build something that matches or is better in accuracy then that - you will have difficulties. Have you considered lowering your goal a little?
Message 12 of 14
(1,931 Views)
Just out of fun I plugged in our 1GHz 8bit digizer to the 5500-2 and recorded a full cycle of 1kHz test signals with 500MSps.
There were about 800 samples at zero crossing - with fuzzy edges.
Guess what your problem really is Smiley Happy
Message 13 of 14
(1,929 Views)
Ransu,
Thanks for the information.  Although he has not admitted it, I think the original poster had a school assignment.  I suspect that someone took a quick look at the instrument specs and said "Measure what it puts out."
It could still be a good learning tool, but some realism should be applied.
Lynn
Message 14 of 14
(1,920 Views)
