Please help to explain the way to set baudrate CAN for NI-XNET
Before, there is baudrate option in xnet module. And I just input 125000 as the baudrate for the program. After the NI-XNET updates, it is required to use baudrate64 option. So what should I input for 125000 in this case.
I have read this: https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000YIf5CAG&l=en-VN. And it seems that I can choose different options to choose baudrate 125000. It seems so complex to me. I just only need to input 125000 the same as 32 bit version of NI-XNET before. Can anyone help to teach me? Thank you very much
(672 Views)
Just wire 125000 to it. You only use the complex value (that can be obtained from NI-XNET Database Editor) if you want to set a custom sample point, which only matters at a higher baud rate of 500k and above.
https://tmesystems.net/
(654 Views)
