Problem in recognizing modules NI9203 and NI9234 with the cRIO 9022 controller.
I have a system composed of a cRIO 9022 controller and two modules NI9203 and NI9234 placed in the same chassis- The 9022 is connected to my PC.
However, I cannot find the modules nor in MAX (Measurement & Automation Explorer) nor in Project Explorer window of Labview, nor in in Distributed System Manager.
The strange thing is that in Project Explorer window of LabView, the description of the controller, instead of it is: "RT -  Desktop target".
Can someone suggest me how to do in order to see those modules from Labview (and then be able to configure and use them)?
Thanks to everyone.
PS Enclosed files support what I have described.
(2,047 Views)
Did you follow this instruction?
http://www.ni.com/tutorial/54281/en/
This is a good walk through to get started. You probably don't have proper software installed on your cRIO and you mistakenly added a Desktop RT rather than cRIO onto the project explorer.
(1,994 Views)
