Problem with saving data to the txt file
Yes, I am looking at the saved file by ftp of windows. I open Windows explorer I put ftp://10.0.0.2 ( IP of device and I can explorer the hard drive) I do exactly the same on Vista and XP. I see txt files and I read them but I see different values.
I will go to my laboratory. The device is running and I will try to copy files which are save on XP and after on Vista and then I will post here.
Message 11 of 13
(1,509 Views)
Are you also copying files that you are still writing to?
Kind Regards,
Thierry C - CLA, CTA - Senior R&D Engineer (Former Support Engineer) - National Instruments
If someone helped you, let them know. Mark as solved and/or give a kudo. 😉
Message 12 of 13
(1,504 Views)
Accepted by topic author Nemesis
I think I found the mistakes. The txt data on XP are opening automatically on WordPad. And when I want to see values by opening on cRIO hard drive it shows bad values. I have just copied files to show you on my USB key and I opened it from the USB key. I noticed that values are correct. I do not understand why I do not have that problem on Vista but it seems to be a problem of Windows/WordPad than Labview. I did not expected to have a problem there.
Thank you for your attention and help.
Message 13 of 13
(1,502 Views)
