Profibus interface
i want to interface comsoft profibus hardware using NI cRIO 9024 chassis with Siemens control card 320-2dp hardware. we sent command but no response. it has been programmed in starter software and command by Siemens plc. but now we want to connect it with cRIO.
thanks
(5,377 Views)
Hi Vaibhavsl,
We need a lot more information. Are you using the profibus c-series module? Can you get screenshost of you configuraiton? is the plc a master or slave? how did you configure the c-series module?
Jesse Dennis
Engineer
INTP
(5,368 Views)
