Programmatic control of secondary NIC
It is possible for a PAC to reconfigure its own primary network settings via the ni-rt.ini file (using the [TCP_STACK_CONFIG] section), however what about the secondary network interface? Is there a way to programmatically configure the static IP of that NIC?
Message 1 of 1
(4,110 Views)
