Programmatically connect LabVIEW application to cRIO on computer without LabVIEW development system
Dear NI geniuses,
I have a probably stupid question.
I have worked for months on a application that includes VIs that runs on a cRIO on one side, and another part that runs on a host PC. I use network streams to communicate beween the two.
I have created a source distribution that is deployed on my real-time target, and I can start it from my host VI on the PC using the VI server. I even created an application with the PC side of my application, and it works fine, as long as the cRIO was previously connected in a LabVIEW project.
But it seems that if the cRIO has not been connected in a project, it won't communicate with the host when I launch my application (without having rebooted the cRIO in between). I would like to transfer my application to a computer without the labview development, but I'm not sure how things are going to go with this connection to the cRIO.
Do I have to programmatically connect to the cRIO before opening the application reference via VI Server or should the 'Open application reference' VI also do the connection ? It is no clear at all to me...
Thanks for your help
(1,852 Views)
You need to build a RealTime application and deploy it to the cRIO and make sure it is deployed to run on boot.
(1,826 Views)
Thanks for your reply. So you mean that  it is not possible to use just a host PC as an application and a source distribution ?
(1,793 Views)
The cRIO is its own computer.  You have to treat it as a different computer.  You deploy an application to the cRIO and then it can run that application when it is turned on.  You can then use TCP/IP to communicate between the application you have running on the cRIO and the application you have running on your PC.
(1,788 Views)
