Quadrature Mode on 9401 for cRIO
Hi All,
I'm using 6 of 8 channels on the 9401 on my cRIO unit (9022 Controller w/ 9113 Chassis) for Quadrature Input. Once I enabled the Quad mode for Q0 & Q1, I lost the two additional channels available on the unit. Is it possible to regain those in Scan Mode, instead of moving the module operation into FPGA mode? My outputs are now P0, P1, V0, V1. Thanks.
(3,529 Views)
Gaussy,
Unfortunately, what you are describing is not possible.  You will have to add another module, or use the module in FPGA interface mode.
Sebastian
(3,524 Views)
