Question about RT data transfer to PC host
I have question related to cRIO data transfer to PC host as document attach.
I'm using cRIO-9064 with module NI-9401.The module 9401 is used to send pulses to the encoder and get back current position with the sampling rate of 5000 samples/s.
Data transfer from RT to PC through NPSV.
thanks,
Simon
(2,725 Views)
So what is your question?
In general, I say to avoid NPSVs like the plague.  UDP, TCP/IP, or Network Streams are much more reliable.
(2,698 Views)
