Question regarding silent install of NI-DAQ from the Command Line (Windows Only)?
I tried installing NI-DAQ From the Command Line (Windows Only), following a document found @ni.com for silent install of NIDAQ6.8.1 and I am quite successful with it. However I am prompted to restart the computer once the silent install is done and after restart I am presented with a setup wizard to install documents. I *DO NOT* want either of these to come up as this adversely affects our remote install automation. Is there anyway to disable this. Please advice.
(5,563 Views)
There is a patch on the NI ftp site for NI-DAQ 6.8.1 that will allow you to avoid the documentation setup after reboot.
Check out the text file at ftp://ftp.ni.com/support/daq/pc/ni-daq/6.8.1/SilentInstall/ and also the executable that is found there.
(5,563 Views)
