RADAR Simulator using FPGA 7976 and VST 5840.
Helo all,
     I am using FPGA 7976 and Second generation VST 5840 for RADAR simulator application, currently I'm using Labview 2015 but facing driver problem so please suggest me whether VST support Labview 2018 or not and what are all the required drivers for VST other than RFSA, RFSG, RFmx,???
For VST 5840 Instrument drivers are not available, only the reference 5840 code is available but it is showing dependency error when I tried to open this vi from a labview 2015.
What is the required driver and any instrument drivers available to configure VST 5840...??????????????????
Regards
Ganesh kumar
(2,762 Views)
I would start with the RF Device Drivers http://www.ni.com/download/ni-rf-device-drivers-may-2018/7686/en/
Certified LabVIEW Architect, Certified Professional Instructor
ALE Consultants
Introduction to LabVIEW FPGA for RF, Radar, and Electronic Warfare Applications
(2,726 Views)
Thanks for your reply Terry_ALE
I have already installed this RFDRVSUITE201805.zip drivers also, but the thing is VST 5840 will support the Labview version starting from Labview 2015 SP1.
(2,721 Views)
Hi Ganesh,
Are you still having issues? Are you mostly using rfmx or rfsa? Are you doing this all on the host?
(2,482 Views)
