RIO Evaluation Kit FPGA Compilation
When runing compilation, the compilation status shows "Compilation erro", but the Xilinx log is empty. Hane no idel what's wrong.
The envirement:
LabVIEW 2015 professional development sp1
LabVIEW FPGA Compile Worker 2015
LabVIEW RIO Eval Kit
Uninstalled/Reinstalled "LabVIEW 2015 professional development sp1", "LabVIEW FPGA mudle" and "LabVIEW FPGA Compile Worker 2015", but does not help.
Please help!!!
(4,997 Views)
Hi Turck,
Thanks for posting in the forums! Do you have the Xilinx compilation tools installed on your host PC where you are deploying from? Which operating system are you using on your host PC?
Tina K.
Applications Engineering
ni.com/support
(4,975 Views)
Hello, Tina,
The OS is Windows XP Pro, SP 3, Version 2002, and has "LabVIEW FPGA Compile Worker 2015" installed.
Turck
(4,971 Views)
Accepted by topic author Turck
Hi Turck,
You may want to take a look at this forum post, where another user seemed to have a similar problem as you: http://forums.ni.com/t5/Academic-Hardware-Products-ELVIS/fpga-compilation-error-LabVIEW-2015/td-p/32...
My guess is that this has to do with an error in the Xilinx Tools Vivado download. Since you are using LabVIEW 2015, you will need Vivado 2014.4. Based on your initial screenshot, it looks like you are using this version. Do you know if you have other versions installed on your computer? If you do, it's possible your dlls are pointing to the incorrect reference from a different version.
I recommend repairing your installation of Vivado 2014.4. You can repair it based on the installation found at the following link: http://www.ni.com/download/labview-fpga-module-2015/5492/en/
Tina K.
ni.com/support
(4,963 Views)
Hello, Tina,
I am sure the PC has Vivado 2014.4 installed only. I did everything I could, uninstall/reinstall/repair/update... Still can not get it work, neither local nor remote, same problems, but Xilinx log is empty.
Turck
(4,933 Views)
This screenshot was taken from MAX. If click "Next", it runs forever, and does not show any error information.
(4,921 Views)
