RIO eEval Kit is not communicating with my PC
RIO eEval Kit is not communicating with my PC running windows 10 connected with CROSSOVER CABLE.When I run setup utility on the hardware detection following message is seen:
Code  -2147467259
nisyscfg.lvlib:Find Systems.vi:1<APPEND>
<b>Complete call chain:</b>
     RunDetection.vi
     EvalUtil.vi
othmen
(2,279 Views)
The error code in the screenshot is different from the error code you entered as text here.
could you tell us the order in which you see the error messages popping up?
Also, I found this solved post that might be helpful here.
(2,253 Views)
