RMX-412x Wireless Control via LAN (Ethernet)
Hi there,
Are there any pre-existing user interface program (GUI) already developed for the RMX-412x power supply to control it wirelessly via Ethernet? Or any GUI built-in web server remote control access with standard web browser such as Microsoft Internet Explorer? Any suggestion for this approach is appreciated.
Thank you,
Nam
Message 1 of 9
(1,191 Views)
I'm pretty sure they are LXI compliant. Just enter its IP address in your browser.
Message 2 of 9
(1,167 Views)
I guess my question is, how do I control and program the voltage after I connect the power supply via LAN? Is there any GUI provide to control the voltage etc....
Message 3 of 9
(1,162 Views)
Per the LXI standard, an instrument must provide a web page interface (ie GUI) for controlling the instrument. All you have to do is point your web browser to the instrument's IP address.
Message 4 of 9
(1,141 Views)
Hi There,
I'm not able to locate where in the user's manual or the program manual that said it has LXI complaint on there. So goal is to remotely control with LAN (LXI compliant) and has the GUI similar to the one show in the figure below.
Can you help point me to where I can find this information.
See the user manual and the program manual below.
Thank you,
Message 5 of 9
(1,126 Views)
I used the RMX-4101, which was released at the same time as the RMX-412x. It had a web browser interface that let me do everything with it. I have no reason to believe it would be different browser code for the RMX-412x. Even the manuals you posted mention a web browser interface for configuration.
Message 6 of 9
(1,121 Views)
Yeah, I saw it mentioned about the browser but nothing about the LXI and I'm not sure if anything different between the two.
Thanks Again.
Message 7 of 9
(1,117 Views)
Hi crossrulz,
when you said, it let you "do everything with it". Did you mean control it using command or does it provided GUI like panel to where set the output voltage and monitor voltage directly etc... like the GUI of the Keysight N5700 I posted above?
Thanks again,
Message 8 of 9
(1,106 Views)
Accepted by topic author Namph
Yes
Message 9 of 9
(1,101 Views)
