RT Apply Target Network Settings: Can a cRIO set it's own IP address...
Was seeking a way to to progammatically set a cRIO's port 1 IP address from the target it'self -
1) without having to know as-shipped IP
2) and without having to know as shipped MAC ID
Get Target Info works fine with loopback address so I undbundle the MAC ID, and use it for the Apply Target Settings. Which errors out on 56.
NI_Real-Time Libraries.lvlib:FPC Discover systems (all interfaces).vi<APPEND>
<b>Complete call chain:</b>
     NI_Real-Time Libraries.lvlib:SetTargetConfig.vi
     NI_Real-Time Libraries.lvlib:RT Apply Target Network Settings (Static).vi:1
     TargetInfoTest.vi
Apply works fine when I provide the MAC ID of the target, and run it on the development pc. But I was trying to avoid having to record the MAC ID.
I wanted to have the cRIO set it's own IP address on initialization - and retrieve the address from a gxml file.
Is this possible?
(5,594 Views)
You could try using the RT Get Target Information (All) rather than  RT Get Target Information (IP). This would retrieve all the discoverable targets on your host computer (example here: https://decibel.ni.com/content/docs/DOC-20299 ) and you could filter (maybe by serial number or model code) to get the MAC address of the cRIO in question. With the MAC address, you said you were successfully able to change the IP address right?
(There's also this example: https://decibel.ni.com/content/docs/DOC-17873 , but it seemed like a much more round about option)
(5,582 Views)
The point is, I wish to run this on the target who's IP I wish to set. Not on a host computer.
I can get the mac id of the target without issue. The loopback IP of 127.0.0.1 does this fine (so long as the port is connected to a switch - I presume).
The issue is once obtained, using the mac id on the RT target it'self with the apply target netwrok setting function doesn't work.
I had hoped someone had a clever work around.
(5,572 Views)
Accepted by topic author S1ack
If you look at the second link I posted, it talks about going into the .ini file and changing the IP address there. I think this method could be done from the cRIO itself; however, in general we don't recommend having the cRIO set its own ip address. I imagine this is why the "Apply Network Settings" VI errors out. Having the cRIO set its own IP address can be problematic if it sets itself to something the computer is unable to find. Good luck!
(5,570 Views)
OK, I can make that work. If I have to. could be a bit risky. But I will cross that bridge when I have to (production units will require unique IPs - so says the customer).
(5,565 Views)
