RT Communication Wizard error 1055
When i use the Real Time Communication Wizard i get this message: Error 1055 occurred at Property Node in RTCW Script NPL (TCP).vi->RTCW Wizard.vi
Whats wrong??? I get this Error in every VI but i´ve already re-installed RT
(4,594 Views)
This is a known and solved issue that is documented in the NI knowledgebase. Please follow this link.
Best regards
Jochen Klier
National Instruments Germany
(4,584 Views)
Thanx, but i can´t solve the problem.
I also get this error when i only have 1 switch, led or something else.
I dont have any groups.
Error 1055 occurred at Eigenschaftsknoten in RTCW Script NPL (TCP).vi->RTCW Wizard.vi
Possible reason(s):
LabVIEW: Ungültige Objektreferenz.
(4,580 Views)
As I can't reproduce this problem could you please attach an example that demonstrates this behavior?
Jochen
(4,578 Views)
I solved this problem.
With a new comm_wizard.llb from the Real Time CD all works fine. Seems that i have overwritten a subVI unintended.
(4,574 Views)
