RT stand-alone VI
I've built a stand-alone application and set it as startup. Is it possible for a VI running on RT to distinguish whether its running from a stand-alone application?
The thing is, when I control the VI from PC, I need to monitor some data (for debugging) but when runnning as stand alone, I dont need that as the data keeps accumalating and will run out of memory sometime. If there is spme kind of a property of VI that can be used to determine if its a stand-alone app, I can create some logic so that VI behaves differently when I build the stand-alone app.
(4,000 Views)
Accepted by topic author Shiva419
The Application.Kind property will be "Run-Time System" when you build an exe. Or you can use the the conditional disable structure to create your own conditions.
(3,989 Views)
Thanx for the reply.. I'll try it out..
(3,970 Views)
