10-02-2015 12:41 PM
With a single CompactRIO I read all the thermocouples from a module by doing this
I have added a Etherent RIO full of thermocouples as follows:
In my untitled1.vi I would like to do a similar thing as the top picture but pointing at a module on the NI 9148. I would imagine it is a PSP thing but have tried for a day with no luck. Anyone got a clue?
cheers
10-05-2015
05:07 AM
- last edited on
01-09-2025
03:51 PM
by
Content Cleaner
Hey Dhomfray,
Have you tried using Network Streams?
In this configuration you are trying to read I/O which in on another RIO. To do this you need to:
1. Read the value on the Ethernet RIO.
2. Put it on a Network Stream (Write).
3. Read from the Network Stream on the cRIO.
Check out here how to use Network Streams: https://www.ni.com/en/shop/labview/lossless-communication-with-network-streams--components--archite....
I won't take you more than 30 minutes to make it run 🙂
Good luck and keep us updated!
Cheers,
Bozhidar
10-05-2015 08:25 AM
Did have a look at that method but it was a problem of knowing when the data set was created. I would like a method of collecting data from both the primary compactRio and the EthernetRio at the same time. Its a shame there is not an easy method of just collecting the whole module using a similar method already used
10-05-2015
08:38 AM
- last edited on
01-09-2025
03:51 PM
by
Content Cleaner
Hello Dhomfray,
The goal of the application is to read data on different modules on different devices away from each other. However, simplified, it is usually not a simple process.
Have you checked this one: https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000x4LaCAI&l=en-US
Check the last figure how the VI is configured and give it a try.
Best,
Bozhidar
