Read Values from Siemens PAC3200 with Labview
Hallo,
I have a problem with the connection between the energy measurement instrument Siemens PAC3200 and labview.
What components I have to use for it?
I've connected the instrument via Ethernet cable to my PC. But if  I tried to read the values I get an error...
Is it possible to connect the measurement instrument to PC without any adapters or something else?
I have already read the manual of the PAC3200. There is a table of variables. They use the function code 0x03 and 0x04, but I haven't any
ideas how to use it in Labview...
The modbus library is already installed. I use Labview2011 and I already installed Real-Time-Addon.
I hope someone has an idea, to solve my problem.
Thanks for your help!
Günni
(6,176 Views)
I suppose you are using NI-VISA to communicate with the instrument?
Ethernet Instrument Control Tutorial
(6,165 Views)
