Real time control with with normal USB-DAQ
I'm doing a project where I want to control a proportional pressure regulator by giving it an input voltage from 0 - 10 V. However, readings from a distance sensor will determine the level of regulation.
My question is whether a normal NI DAQ such as the USB-6212 will be able to do this with a relatively good and constant response time for the output signal? I've had a look at the real time controllers as well, but they seem to me like a too powerful and expensive option for a relatively simple problem?
I'm looking at an output response time of at least 0.2 s, but faster will obviously be better. I realize that a DAQ is more for sampling and saving a lot of data rather than using this data as a control input for an output port. I've been warned that a DAQ will probably not work great for this application and that I should rather consider something like a PLC or microcontroller setup. I was still curious on whether it may actually work with a normal DAQ?
I'll appreciate any light shed on this topic.
(2,699 Views)
Accepted by topic author EBIE
If jitter is your concern, then avoid Windows like the plague when it comes to your control processing.  Furthermore, I would also avoid USB (I find it to be unreliable for various reasons).
Personally, I think a simple Arduino setup will meet your goals and be fairly cheap.
(2,687 Views)
